Help Light Sensor Broken?
Rodent
Member
Seems like the light sensor is jacked, or the phone is. The screen will go from looking normal to dimming too almost unreadable(unless in a dark room). Even if I set the screen brightness to full and turn off auto screen it still does it.
Anyone else seen this happen? Seems to be a few times a day.
Ideas?
Btw this is Verizon SG3 2 days old.
Ideas?
its very touchy, even the proximity sensor was getting annoying when I was trying to type in my voicemail password the screen would black out
Ideas?
Download "Android Sensor Box" from the play market. Select "Light Sensor". This test should show a high lux (120+ for example) in a brightly lit room and 0.0 in complete darkness.
I think it's the Auto brightness and the Auto adjust screen tone fighting it out for control over the screen brightness. I turned off both and don't have the ups and downs I used to. Both settings are in the Display section of Settings. You might try just turning off screen tone and see if that helps.
Ill give this a try, hopefully it helps!
Thanks!
Sooo I'm having the same problem and my light sensor isn't reading anything over a 45. Is there some way to fix this?
