Help Lights between keys
chris100575
Does anyone know if it's possible to turn off the lights between the three keys on the front of the X10? My GF's just got one, the lights annoy her and neither of us can figure out how to turn them off. :confused:
I doubt there is an option, but what you can do it cover the lights under you're thumb.
It's not the best solution, but it's not the worst problem either
You cant turn them off. They are 2 LED'S that respond when you press 1 of the 3 buttons.
Hope this helps
since i debranded mine...only the left one works now
not exactly a great loss!!
