link 2 sd not working
Hey..i have just installed.link 2 sd. And unlike before it doesnt seems to work right.
So lets get to the key.points
I am using gts6012 rooted n havin tecnoduos1.
I have a 4 gb memory card . I have a second partion in ext3 type and it has about 290mb.
Okay...after that i installed couple of google.play apps... I saw that some apps are installed and.moved to sd ..while for other apps.like tapatalk and monster crew and all..it is Just showing that .its been linked to sd ...and then.when.i.checked.my internal memory..i.noticed that all the apps (highlighted with "linked to sd ") are taking their usual space ...so basically.link 2 sd didnt work right...then i checked link 2 sd and opened those apps amd i was not able.to toggle with the move to sd option...
Thats it. There is my problem.
Please help.
Thanks in advance
Sent from my GT-S6102 using Tapatalk 2
