link2sd help. cant create 2nd partition
mrpinkeye
iv spent 3 hours trying to do this with 2 different programs (easeUS and minitool) and iv got nowhere and after searching the web i find no help :(
i have a 32gb micro sd card in my phone
i plug phone via usb into computer
minitool finds the drive and shows 30gb fat32 space
i resize OR split this (iv tryed both) to give 27gb fat32 and 3gb unallocated
THEN i when i try to create a partition using the unallocated space it says something like "cannot create...you must delete the partition"
the only thing i can delete is then the 27gb fat32 and all that does it remove the drive letter so windows cant see it
grrrrrr this is driving me mad. can someone help please! my lg optimus l3 has 1gb and for some reason i can only have around 10apps on it! arghhhh
