Help Link2sd issue
junior187
Hi sometimes my sdcard unmounts it self and the programs on link2sd dont work even after the remount , i believe link2sd is the cause even sometimes when the sd card is mounted with no problems it doesnt find the 2nd partition on the sd card which means i have to remove the battery so the apps on link can work again, is it the phone? should i reset? is my mem card messed up?(i doubt because only the 2nd partition dont work, can still view pics and music on it) or the link2sd program it self? thanks.:confused:
I have a rooted Optimus V and have had no problems with Link2sd. Maybe the ROM is giving you problems working with Link2sd? I am still running the stock ROM.
What format is your second partition? I use fat 32, could try a different one than you're using?
