I have been using link2sd for almost 6 months and it has worked flawlessly, except when i try to link apps that are bigger than the internal storage available.
Examples
Internal memory - 40mb remaining
Primary partition - 12 gb remaining
2nd partition - 1gb remaining
size of app trying to link - 20mb
The above scenario the link is succesful
size of app trying to link - 45mb
The above scenario the link fails.
Is there any fix to the second scenario? I have enough space on the 2nd partition so i'm guessing there whould be a work around...
Thanks in advance.
Examples
Thanks in advance.
