Help Liquid E2 Duo V370 SIM Toolkit STK or Lycamobile issue?
Hoping someone can help with this as it is driving me nuts!
I have the Acer Liquid E2 Duo V370 dual sim phone running Android 4.2.2, with build Acer_AV061_V370_1.032.00_WW_GEN1. I have a Lycamobile UK SIM and a Toggle UK SIM in the phone (for info, Lycamobile and Toggle are effectively the same company). With Lycamobile and Toggle you sometimes need to use the SIM Toolkit to access the SIM itself to switch/latch modes on the phone to select the network. SIM Toolkit will not let me access the Lycamobile SIM on this phone, but has no problem with any other SIM and the Toggle one). If I swap SIM slots to see if that is the issue I still cannot access the Lycamobile SIM. If I put the Lycamobile SIM in another Android I can access the SIM OK and change the settings I need to there. I am just mystified as to why the V370 is not able to recognize the Lycamobile SIM.
Lycamobile does appear in the list when I open SIM Toolkit but if i click on it I get the message "Application is not installed on your phone".
If I go into Manage Apps I can see 2 SIM Toolkit entries there: one is titled SIM Toolkit, one is called SIM Tool Kit. SIM Tool Kit is version 4.2.2 eng.call2.13888656137; SIM Toolkit is Version 1.0.
As for swapping SIMs into different slots I have tried almost every variation possible I think: I put the Lycamobile in slot 1, same error, and then slot 2, same error; I tried it with the Toggle in slot 1 and slot 2 and it works as expected each time; I have tried it with Toggle in slot 1, Lycamobile slot 2, same error, Lycamobile in slot 1, Toggle in slot 2, same error. Later tonight I am going to get the other phone out and see if I can see if there is an obvious difference but SIM Toolkit has been around for years so this is very confusing to me - Lycamobile obviously have the stuff on the SIM that should be there but the V370 does not like it. I have also put other SIMS in both slots and all are read successfully
The other phone is a ZTE V790 Android 4.0.4, SIM Toolkit is 4.0.4-20121213.152757.26676. With one SIM enabled in phone I have SIM Toolkit in the app list, when I enable the second SIM, then SIM Toolkit2 appears in the list and I can access the Lycamobile SIM just fine.
Any clues as to why the Lycamobile SIM not recognized on this one particular device (Acer V370) but is fine in others? I have asked Lycamobile but we are bandying emails at the moment and not really getting anywhere.
For people that have smartphones that do not have SIM Toolkit installed, is there a set of #### codes you give them to choose between Automatic and Manual modes? If so, I am happy to use those as a circumvention if you can provide them to me.
The phone is rooted and I have the stock Acer ROM installed.
Thanks.
