if you're missing com.system files then you either got a bad download, bad flash, or modified your .zip file. Redownload the file, CRC/MD5 check the download, transfer it to your phone or means of flashing and make sure the MD5 still checks out, make sure you do a completely clean flash from recovery and make sure there is no errors when flashing.
Also, there is no stable 4.4.x yet.
:what:You're wrong. The Snapshot builds of CM11 are stable.
It says com.android.systemui
