Apps ListView Help: Resource Not Found
piper210
Hi people.
I am working on a project an am currently blocked. I created an arraylist with the info I want displayed in the listview. I used an array adapter and put that in the setListAdapter. All this is done by the book.
However, when I run it, it goes through the whole program and then gives me an error that it can't find the list_item.xml resource. I check the path that it gave an it is there. I tried cleaning the project and restarting the computer but nothing works.
Does anyone have any ideas as to how I can fix this? I'd really appreciate the help.
Additional Info: I have been doing tests and it I learned that the program messes up when I use setListAdapter(value).
fyi: The variable value is what i get from the array adapter.
Hope this info is useful. I really need some help to solve this. I honestly don't know what to try next.
Hi people.
Code:
public class waFinalActivity extends ListActivity {
	static ArrayList<String> stations=new ArrayList<String>();
	/** Called when the activity is first created. */
	@Override
	public void onCreate(Bundle savedInstanceState) {
		getAvailableStations();
		ArrayAdapter<String> value=new ArrayAdapter<String>(this,R.layout.list_item,stations);
		System.out.println("test1");
		setListAdapter(value);
		System.out.println("test2");
		ListView lv=getListView();
		lv.setAdapter(value);//<------------ gets stuck here
		lv.setTextFilterEnabled(true);
		System.out.println("test3: setting");
	/*protected void onListItemClick(ListView lv, View v,int position, long id){
		super.onListItemClick(lv,v,position,id);
		String openStation=stations.get(position);
		try{
			Cla
		catch(){
	/**********************************get station IDs***************************************/
	private void getAvailableStations() {
		AssetManager am=getAssets();
		InputStream s = null;
		try{
			s=am.open("fl_wx_index.xml");
			DocumentBuilderFactory dbFac=DocumentBuilderFactory.newInstance();
			DocumentBuilder db=dbFac.newDocumentBuilder();
			Document doc=db.parse(s);
			doc.getDocumentElement().normalize();
			NodeList nL=doc.getElementsByTagName("station");
			for(int i=0;i<nL.getLength();i++){
				Node n=nL.item(i);
				if(n.getNodeType()==Node.ELEMENT_NODE){
					Element eElement=(Element)n;
					String value=getTagValue("station_id",eElement);
					stations.add(value);
			am.close();
		catch(FileNotFoundException e){
		} catch (IOException e) {
			// TODO Auto-generated catch block
			e.printStackTrace();
		} catch (SAXException e) {
		} catch (ParserConfigurationException e) {
		finally{
			try {
				s.close();
	private String getTagValue(String sTag, Element eElement) {
		NodeList nlList = eElement.getElementsByTagName(sTag).item(0).getChildNodes();
		Node nValue = (Node) nlList.item(0);
		return nValue.getNodeValue();
it extends listactivity so setContextView() doesn't have to be called.
It shouldn't effect the result event if it is there, but I tried putting it and it gave me an error.
