Little cheat for My Country
Saltine713
**SPOILER: THIS IS A SMALL CHEAT FOR UNLIMITED MONEY. If you do not want this, then don't look.**
Anyway, when I was adding water to my city, I decided I didn't want it. So I was using the little bulldozer to change it back to grass when I noticed that the price goes down, and eventually to negative if you click on the same spot a lot. I did this for a while, and got $50,000,000.
All you need to do is:
1. Place a lot of water.
2. Using the bulldozer tool, keep tapping in the same spot until the money goes to -.
3. It goes by $10,000 for each press, so enjoy!
Sorry if this isn't allowed, not sure if cheats are allowed to be posted.
Thanks for the tip. Actually it worked fine until I decided to start all over again. Had to uninstall and reinstall, and the cheat doesn't work anymore... What a bummer.
