I don't know anything about a .BIN file being used but you should be able to use a .SCR & .TOT file. Try this guide, it's been posted before in this forum. What exactly did you do to your phone?
When you choose the .BIN file you will actually use the .TOT file. In windows 7 I did this procedure but I had to navigate to the directory of the .TOT file and manually type the file name before clicking open. The browser for LGNPST only wants to open .BIN on that option. As long as your phone can get a serial connection to LGNPST you should be able to repair it. Good luck mate & good luck with that ICS
