Help Live stream keeps dropping
Paul Mars
Live streams continually drop, rarely recover w\o me refreshing the browser. I tried the apps too, but that didn't help. Applies to wifi and data connections. Phone company reset the service not help. I've twice done a factory data reset, which didn't fix it. Only other apps I've installed are blue mail and goodev volume booster and zoom.
ZTE Z719DL
V 7.1.1
Did you check battery optimization settings for the apps that stop?
Settings
Apps & notifications
Advanced
Special access
Battery optimization
<arrow to the right of Not Optimized>
All apps
(find the apps in question, be sure that they are not optimized)
Settings
See all
Overflow (3 dot icon upper right)
Show system
Android System Webview
Advanced
Battery
And it looks like I was mistaken, Background restriction is what I was thinking of.
Ok.
I am going to assume that your device is using Chrome as a webview.
That was typical for a time.
Go to developers options, and select Webview implementation.
You most likely have Chrome and Android System Webview as your options.
See if you can select Android System Webview.
If you cannot,that means that you have a device that requires you to disable Chrome in order to be able to do this.
Personally, I don't use Chrome, or any Google apps (on the device that I carry), so this was no loss to me.
If you use Chrome as your browser, I can suggest a few that are so much better.
Anyway, check on the above first and then see if switching makes any difference.
In settings.
You have to first reveal them., if you have not already.
Settings
System
About phone
Build number
(tap build number 7 times)
Then back out of settings, enter
Settings
Advanced
Developers options
