kodiak211
Member
I'm trying to build a live wallpaper using frames. I can't find any good tutorials on how to even build a live wallpaper. When I run app from eclipse i get these errors.
[2012-05-19 22:26:32 - LiveWallpaper] No Launcher activity found!
[2012-05-19 22:26:32 - LiveWallpaper] The launch will only sync the application package on the device!
It does install to the emulator. It all seems to work. I go in to the live wallpaper menu, find my live wallpaper in there open it, it loads. but its not moving through the frames. It only shows the last frame. I set it as wallpaper. It also doesn't do anything. Also would like to center the images. Hears my code...
Java class--->
import android.graphics.Bitmap;
import android.graphics.BitmapFactory;
import android.graphics.Canvas;
import android.service.wallpaper.WallpaperService;
import android.view.SurfaceHolder;
public class WallpaperSer extends WallpaperService {
public void onCreate()
super.onCreate();
public void onDestroy()
super.onDestroy();
public Engine onCreateEngine()
return new WallpaperSerEngine();
class WallpaperSerEngine extends Engine
public Bitmap image1, image2, image3, image4, image5, image6, image7, image8, image9,image10,
image11, image12, image13, image14, image15, image16, image17, image18, image19,image20;
image1 = BitmapFactory.decodeResource(getResources(), R.drawable.and1);
image2 = BitmapFactory.decodeResource(getResources(), R.drawable.and2);
image3 = BitmapFactory.decodeResource(getResources(), R.drawable.and3);
image4 = BitmapFactory.decodeResource(getResources(), R.drawable.and4);
image5 = BitmapFactory.decodeResource(getResources(), R.drawable.and5);
image6 = BitmapFactory.decodeResource(getResources(), R.drawable.and6);
image7 = BitmapFactory.decodeResource(getResources(), R.drawable.and7);
image8 = BitmapFactory.decodeResource(getResources(), R.drawable.and8);
image9 = BitmapFactory.decodeResource(getResources(), R.drawable.and9);
image10 = BitmapFactory.decodeResource(getResources(), R.drawable.and10);
image11 = BitmapFactory.decodeResource(getResources(), R.drawable.and11);
image12 = BitmapFactory.decodeResource(getResources(), R.drawable.and12);
image13 = BitmapFactory.decodeResource(getResources(), R.drawable.and13);
image14 = BitmapFactory.decodeResource(getResources(), R.drawable.and14);
image15 = BitmapFactory.decodeResource(getResources(), R.drawable.and15);
image16 = BitmapFactory.decodeResource(getResources(), R.drawable.and16);
image17 = BitmapFactory.decodeResource(getResources(), R.drawable.and17);
image18 = BitmapFactory.decodeResource(getResources(), R.drawable.and18);
image19 = BitmapFactory.decodeResource(getResources(), R.drawable.and19);
image20 = BitmapFactory.decodeResource(getResources(), R.drawable.and20);
public void onCreate(SurfaceHolder surfaceHolder)
super.onCreate(surfaceHolder);
public void onOffsetsChanged(float xOffset, float yOffset, float xStep, float yStep, int xPixels, int yPixels)
drawFrame();
void drawFrame()
final SurfaceHolder holder = getSurfaceHolder();
Canvas c = null;
try
c = holder.lockCanvas();
if (c != null)
c.drawBitmap(image1, 0, 0, null);
c.drawBitmap(image2, 0, 0, null);
c.drawBitmap(image3, 0, 0, null);
c.drawBitmap(image4, 0, 0, null);
c.drawBitmap(image5, 0, 0, null);
c.drawBitmap(image6, 0, 0, null);
c.drawBitmap(image7, 0, 0, null);
c.drawBitmap(image8, 0, 0, null);
c.drawBitmap(image9, 0, 0, null);
c.drawBitmap(image10, 0, 0, null);
c.drawBitmap(image11, 0, 0, null);
c.drawBitmap(image12, 0, 0, null);
c.drawBitmap(image13, 0, 0, null);
c.drawBitmap(image14, 0, 0, null);
c.drawBitmap(image15, 0, 0, null);
c.drawBitmap(image16, 0, 0, null);
c.drawBitmap(image17, 0, 0, null);
c.drawBitmap(image18, 0, 0, null);
c.drawBitmap(image19, 0, 0, null);
c.drawBitmap(image20, 0, 0, null);
} finally
if (c != null) holder.unlockCanvasAndPost(c);
xml code--->
<?xml version="1.0" encoding="utf-8"?>
<wallpaper xmlns:android="http://schemas.android.com/apk/res/android"
android:thumbnail="@drawable/ic_launcher"
android:description="@string/app_name"/>
manifest--->
<application android:label="demo Live Wallpaper"
android:icon="@drawable/ic_launcher">
<service android:label="demo Live Wallpaper"
android:name=".WallpaperSer"
androidermission="android.permission.BIND_WALLPA PER">
<intent-filter>
<action android:name="android.service.wallpaper.WallpaperS ervice" />
</intent-filter>
<meta-data android:name="android.service.wallpaper"
android:resource="@xml/wallpaper" />
</service>
</application>
<uses-sdk android:minSdkVersion="8" />
<uses-feature android:name="android.software.live_wallpaper" />
</manifest>
Java class--->
super.onCreate();
super.onDestroy();
drawFrame();
void drawFrame()
Canvas c = null;
try
if (c != null)
} finally
xml code--->
manifest--->
<intent-filter>
</intent-filter>
</service>
</application>
</manifest>
