Help live wallpapers on Samsung Galaxy Apollo?
yes, you must wait until april 2011.
Because android 2.2(froyo) for samsung galaxy 3 will be release then.
With installed android 2.2(froyo), you would be able to run live wallpaper
a) Is it possible to install live wallpapers on Samsung Galaxy Apollo
b) If so, Tell me how to plz
Yeah i have installed Live wallpapers on my Galaxy Apollo with still on eclair 2.1...
All u to do is Root d device (at ur own risk) by following dis link
Samsung Galaxy 3 GT-i5800: root, gps fix, upgrading - xda-developers
& den following d simple instructions given in dis link below
xda-developers - View Single Post - Samsung Galaxy 3 GT-i5800: root, gps fix, upgrading
Statutory Warning:- Rooting doesnt harm ur device by any means until it is done corectly & following the correct methods,i rooted my phone once i got well versed wid it & understood the functunality.using it since 3months now....bt i will still suggest 'Root at ur own risk.'
All The Very Best
Hi guys,
I am new to this forum and i just bought my i5801.
And i was disappointed to hear that live wallpaper didnt work on it so i just wanted to ask you guy how i can enable it and which would be save
1.update to froyo
2. Root + live wallpaper
if you select root please can anyone give i kind of video guide because i dont what to mess up.
thank you
to be quite honest I dont see much point in live wallpapers for this phone. Live wallpapers only look good on bigger res larger displays. Imho its not worth the battery and speed drainage.
just an opinion!
Live wallpapers on the Samsung Galaxy Apollo using android 2.1 is easy
1. Download LiveWallpapersPicker.apk and copy it to the memory card of your phone
2. Go onto the Android Market and download "Z4 Root" and "ES File Explorer" (Both FREE)
3. install Z4 root and root your phone (just follow the Instructions on Screen)
4. run ES File Explorer click on "LiveWallpapersPicker.apk" and press either COPY or MOVE, then Navigate to the phone memory (the folder you are looking for is "SYSTEM/APPS"
5. Paste the LiveWallpapersPicker.apk in the folder and reboot the Phone
Congratulations you now have Live Wallpaper
