Kahil
This is my first Android app!
All proceeds from this app will be donated to cancer patients in need. I hope you try it and like it. If you do like it, please rate it high, comment and recommend to others. Thank you!!!
I dedicate this app to my husband Blake and to all others out there fighting cancer.
Live Weather Wallpaper for Android is a live wallpaper that will display your current weather conditions via high-res wallpaper images. Once you set the location in the settings, the app will download the current weather information via the Google Weather service. Our app is only as accurate as the Google Weather service is, so with that in mind we recommend setting your location using zip codes. International users should note that locations outside of the United States are limited by the Google Weather service. Should the weather service report a weather condition that we do not have an image for, a notification will display in the status bar letting you know and giving you the option of reporting it to us so we can update as soon as possible. To save valuable space and resources on your device, we use high-res static (non-animated) wallpaper images stored remotely and the app will only store a single image on your device at any one time.
You will also find a few options in the settings to enhance your experience. There are several refresh intervals to choose from: 30 minutes, 1 hour or 12 hours. Would you like a quick way to view the current weather information? We've got a setting for that as well. Simply enable the touch display options If you enabled the touch setting, then by doing a quick double tap on the device screen, a quick popup will show you the current weather condition and temperature. Why isn't there an option for using GPS to set your location? We opted to not enable this feature in order to cut back on battery use and device resources. Had we enabled this, then the more your location changes, the more device resources and battery usage would be used during the more frequent updating.
If you have any issues, find any bugs or come up with any feature suggestions, please contact me and I'll get back to you with help or an answer ASAP. Thank you!
All proceeds from this app will be donated to cancer patients in need. I hope you try it and like it. If you do like it, please rate it high, comment and recommend to others. Thank you!!!I dedicate this app to my husband Blake and to all others out there fighting cancer.
How many different behaviors does your live wallpaper know?
