3D force tunnel LiveWallpaper
Play market links:
3D force tunnel FREE
3D force tunnel PRO
Tired of all these live wallpapers that have both very little originality and very little options to configure? Well look no further because this live wallpaper has plenty of each! In fact, simply stating that "3D force tunnel PRO" has 'plenty' of configurations may just be an understatement, as there are literally over a quarter million different combinations of options!
Video demonstration:
Screenshots, click to view:
Features:
• Unique textures
• Select the texture itself or choose it random
• Random or choosable fade in/out time between textures
• Custom colors to use as the "light at the end of the tunnel"
• Select segments count itself or choose it random
• Change speed
• Custom time to use as the "light at the end of the tunnel"
• This isn't just a tunnel, it is a Magic!
- added more textures
- added some features from PRO to free
- improved stability
-changed render system(more stable)
-improved speed
-improved stability
-added Blur and Radial Blur effects (all customizable in full version)
-finally I have found bug in my GLES implementation and I fixed it, now "Force Close/Crash" problems in the past
-improved speed for HD devices (you can change picture quality and blur quality in the settings)
-minor bugs fixed
-added brightness option
ENJOY THE MAGIC!!!
Play market links:
3D force tunnel PRO
Features:
• Unique textures
• Change speed
Update v 1.4
Update v 1.4- added more textures
Update v 1.5
Update v 1.5-changed render system(more stable)
-improved speed
-improved stability
Update v 1.7
Update v 1.7-finally I have found bug in my GLES implementation and I fixed it, now "Force Close/Crash" problems in the past
Update v 1.8
Update v 1.8-improved speed for HD devices (you can change picture quality and blur quality in the settings)
Update v 2.0
-improved speed, jep, again-minor bugs fixed
Update v 2.1
-minor bugs fixed-added brightness option
ENJOY THE MAGIC!!!
