George Orwell
I mistakenly loaded the T-Mobile ROM on my N1 AT&T (I did it because of all of the bad info on the web). It automatically rebooted back into the stock version, but I'm now getting weird errors.
The screen won't respond, the applications hang for a long time, it's not unusable, but it is annoying.
I'm assuming the Froyo update will update the ROM and fix this. Would that fix the problem or should I do a factory reset?
Sorry if my terminology is wrong.
Thanks for the help
Thanks for the help
