I'll have to try that location spoofer. Supposedly, if you jailbreak your iPhone, there's an app called Location Faker, that you can use to essentially do the same, with the option of being able to do it for a set period of time, which is all you need for the service I'll be looking to use it with, mlb.tv/at bat 11, b/c once you're logged into the game that mlb blocks you from watching, even if you live up to 10 hours away from the damn team you care about watching in some cases, you can turn the ip faker off & go back to doing what you do.
