Help Location help.....
wedgemoose
I have been wondering about this for a while so I figure it's time to ask.
We have 3 different location settings under "Location On".
Which should I have checked? I noticed that when I have "Standalone GPS" only, that my Weather doesn't always update. So I usually check that and "Google Location" But what is your advise? what is VZW Location used for?
I want things to work but I want to save as much precious batt life as possible. what are you guys using (If any).
thanks
It really depends on your needs!
I too keep Google Location checked at all times.
VZW Location is used for VZ Navigator.
Standalone GPS is used for maps and navigation.
If I were you I would take it on an app by app case...
