I have the Backdrop app that lets you set wallpapers from the IFL website. I have e-mailed the developer but have not received a response. It seems you cannot download the wallpaper to your SD card for re-use at a later date (this was my feature request) so I'm thinking... if I could copy it to my SD card from wherever it is located then It would serve the same purpose. Problem is, I've been searching using Astro file manager and cannot find it.
Does anyone know where Android stores the current wallpaper in use? These are not live wallpapers BTW.
Thanks,
Vlip
Thanks,
Vlip
