Help Location of downloaded apps...?
Marzz
Hi guys. This might sound stupid, or repetitive, so I appologise in advance.
I recently had my SGS updated to 2.2 and noticed a couple of strange apps installed, such as Quran and Prayer Time. Now I've tried to remove them via the standard 'remove app' on the SGS, but found I had to root the phone, which I did. I've now tried to download Ti Backup to delete the above files, and it lets me download the app (Ti Backup) however I can't seem to locate it on my phone, and it doesn't create a shortcut in my apps. Am I am doing something wrong? I've also noticed I no longer have a short cut to the Android Marketplace on the phone.
Thanks for any help.
M.
PS
Uninstall the Titanium Backup from the Market, restart the phone, and the go and download it again. You can also open it from the market itself if you want.
You said you don't have a market shortcut, but then you say when you go to the market, do you have the market or not on your phone?
Hi mate, thanks for the reply.
The problem is, I can't find Titanium Backup anywhere on my phone to either run it or uninstall it.
If I go in too settings - manage applications, and ALL or Third Party, Titanium Backup doesn't appear anywhere in the lists, however if I go online to Android Marketplace, and search for Titanium backup, it tells me it's already installed.
To answer the second part of your question..to access Android Marketplace, I have to open the internet browser and load it up manually.
When you did the update to 2.2 did you a factory reset? I would suggest doing this thing first, make sure you don't have any lag fix running. Do a factory reset from
Settings --> Privacy --> Factory data reset.
After doing so, then you can do the root, and try installing TB and see if you get everything sorted out.
