Hi to all im new to android and i have a small problem and i would really appreciate if someone can help me
first im trying to show all available location providers and its not working and 2nd when ever i run the it i don't get any location information from the best available provider (i have my wifi and network providers on)
thanks in advance
package com.paad.whereami;
import java.io.IOException;
import java.util.List;
import java.util.Locale;
import android.app.Activity;
import android.content.Context;
import android.location.Address;
import android.location.Criteria;
import android.location.Geocoder;
import android.location.Location;
import android.location.LocationListener;
import android.location.LocationManager;
import android.os.Bundle;
import android.widget.TextView;
public class WhereAmI extends Activity {
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
LocationManager locationManager;
String context = Context.LOCATION_SERVICE;
locationManager = (LocationManager)getSystemService(context);
boolean enabledOnly = true;
List<String> providers = locationManager.getProviders(enabledOnly);
Criteria criteria = new Criteria();
criteria.setAccuracy(Criteria.ACCURACY_FINE);
criteria.setAltitudeRequired(false);
criteria.setBearingRequired(false);
criteria.setCostAllowed(true);
criteria.setPowerRequirement(Criteria.POWER_LOW);
criteria.setSpeedRequired(true);
String provider = locationManager.getBestProvider(criteria, true);
Location location = locationManager.getLastKnownLocation(provider);
updateWithNewLocation(location);
locationManager.requestLocationUpdates(provider, 2000, 1,
locationListener);
private final LocationListener locationListener = new LocationListener() {
public void onLocationChanged(Location location) {
public void onProviderDisabled(String provider){
updateWithNewLocation(null);
public void onProviderEnabled(String provider){ }
public void onStatusChanged(String provider, int status,
Bundle extras){ }
private void updateWithNewLocation(Location location) {
String latLongString;
TextView myLocationText;
myLocationText = (TextView)findViewById(R.id.myLocationText);
String addressString = "No address found";
if (location != null) {
double lat = location.getLatitude();
double lng = location.getLongitude();
latLongString = "Lat:" + lat + "\nLong:" + lng;
double latitude = location.getLatitude();
double longitude = location.getLongitude();
Geocoder gc = new Geocoder(this, Locale.getDefault());
try {
List<Address> addresses = gc.getFromLocation(latitude, longitude, 1);
StringBuilder sb = new StringBuilder();
if (addresses.size() > 0) {
Address address = addresses.get(0);
for (int i = 0; i < address.getMaxAddressLineIndex(); i++)
sb.append(address.getAddressLine(i)).append("\n");
sb.append(address.getLocality()).append("\n");
sb.append(address.getPostalCode()).append("\n");
sb.append(address.getCountryName());
addressString = sb.toString();
} catch (IOException e) {}
} else {
latLongString = "No location found";
myLocationText.setText("Your Current Position is:\n" +
latLongString + "\n" + addressString);
thanks in advance
@Override
locationListener);
Bundle extras){ }
try {
} else {
