lock out
  • Start date Start date
A
Android Question
Guest
I have a A1 market 7 inch tablet that i am locked out of i cant enter my gmail bc the wifi isnt on and i cant turn it on and i cant do usb because i cant turn that on either.somebody help me please
Hopefully you'll be able to get into a manual recovery mode to reset the tablet, because at this point, that's really your only option.
This thread might help. http://androidforums.com/android-lounge/691455-lost-stolen-locked-out-device-read-here.html
The problem is going to be how to access that recovery (if it has one). It's usually a combination of the physical keys. You may just have to try holding them down in different sequences. First try vol. down and power together for several seconds. If that doesn't work, try vol. up and power, then try both volume up and down + power. It might take a bit of trying. There also is a chance there is no recovery mode installed, in which case you may need to return it for service.
