Help Lock Screen Boarders?
rikjonno
I have just changed my lock screen wallpaper and now there are to think black lines running vertically down each side of the screen these are not present on the ripple screen only after i have swiped ready to put my pattern in they appear it is like the wallpaper moves position slightly i have tried to change back to the default screen but it is still happing where they like this to start off with or am i going nuts???
Ripple Screen
Lock Screen
In fact when you change your wallpaper you always get a slightly thicker left edge on the screen. You can see this when you put the negative colours widget on screen. Unchanged wallpapers show no white line on the left edge but if you change the wallpaper you will have a slightly thickerleft edge which shows a white line in negative colours. I have tested it on some store models and it always happens.
If the lines go away after you put your pattern in then it's no problem really
