Sorry for that folks. I just switched back to Sense launcher and noticed the shortcuts were switched. Put in the ones I wanted on lock screen and it works great thanks all. One good thing about using another launcher is that you can have different lock screen shortcuts than your dock as it uses the sense ones.
I use Handcent SMS as my texting. So this is for that or any app you want to change on the Droid Razr.
1. Click on Handcent SMS
2. Go to Settings
3. Click on Application Settings
4. Click Default Messaging Application
5. Select All(SMS & MMS)- That will make Handcent the "default texter"
NEXT
1. Go to the "home page" on your phone
2. Go to your applications
3. Scroll through until you find the original Droid texting app
4. Touch and hold down on the app until it comes to your home page and drag it up to the top where it says "More Options"
5. Select App Info
6. On the page that it brings up click Disable. There will be a warning message, but just click ok. Then Handcent should now be the shortcut on your lock screen!
