Root Lock Screen updates for Blue Terror
itzmiandy
Hey Guys,
Here is the lockscreen update that we have been waiting for.
I must tell you that I am a total noob but I wanted to change something about this device because it was my first android device. I had spent many sleepless nights surfing so many sites and browsing through many forums to figure out how to do this..
I am thankful to all the contributors on XDA for all the tutorials they have up there.. Without them I wouldn't have learnt a thing.
Shahabazas is the one who has tested these updates and I guess it is only for the Blue Terror Rom.
Let me tell you the difference this update will do to your device.
On the default Ginger Bread lockscreen:
1. Carrier Names removed
2. Fixed the Unlock/Volume button from falling off the bottom of the screen.
3. Removed the Unlock text that was next to the unlock button
4. Removed the 'Sound is On', 'Sound is Off' text and corresponding icons when using the Volume button
5. Remove all crappy looking status icons form the screen
6. All the elements in the lockscreen has been completely re aligned.. Like centering the Clock, Making sure the emergency button does not overlap any other buttons etc..
On the default Micromax Default Wallpaper: Using Curlockscreen=102
1. Transparent wallpaper
2. Carrier Names removed
3. Removed the crappy looking arrows
4. Removed the text 'Slide to Phone', 'Slide to Messages' and 'Slide to Unlock'
5. Removed the background bar when these texts come up.
6. Removed the margin bars at the bottom of the screen.
On the pattern lock screen:
1. Made the background transparent
2. Made the buttons invisible (change the show pattern view option in the pattern lock settings and it is so much cooler)
3. Removed the clock widget on the top
4. Removed the horizontal divider
5. Removed the emergency call button in the default view.
6. Added custom text "If found, please contact me at xxxxxx@xxx.com
For those of you who can't figure out how to change xxxxxx@xxx.com to your email address, can send a request (Along with your email address) for your email address to be added and I will send you a separate zip.
I will try to add a small tutorial on how to change the text as well..
And hey, as Ninad says "The thanks button will not click itself"
Hey Guys,
I must tell you that I am a total noob but I wanted to change something about this device because it was my first android device. I had spend many sleepless nights surfing so many sites and browsing through many forums to figure out how to do this..
please send me separate zip with custom text as my mail id i.e. drdogautam@gmail.com
thanks.... :)
BTW where is ur update link here....
Download the update from here;
https://www.dropbox.com/s/t2456jbhlmg46jd/Lockscreen Update.zip
Just flash it through recovery without wiping anything..
I have used Firoz's framework to make the changes so there might be some animation or text color that might be different from stock Blue Terror.
There is animation in I guess every app or everything v do n d blue colour is added attraction which is too good n buddy thanks for providing d updates.
Just flashed the zip, looks nice but how to unlock.
Edit: Just found how to unlock. Its like a invisible unlock. It will keep our phone safe from wrong handling.
Can u help on the xxx@xxx.com problem as if i need to add my email and phone number there.
Thanks for your work on lockscreen its great to see you guys working hard on this crap provided by mmx...
I would love to have the fount colour same which is provided my aayush,particularly because i cant see text on white background properly...
Also with this updates we loss our SIM recognition in call logs...
I will be thankful if work work on those two things mention above...
Is there any way to change the lockerscreen wallpaper...also can you make the lockerscreen clock smaller in size so we can have a good wallpaper space...:o
Bro,
There should be no reason for you to loose the sim recognition.. Nothing is changed with that. It should work..
Anybody else has the same complaint??
There is no lockscreen wallpaper now.. Its transparent. To change it, you need to decompile the framework-res.apk and edit an XML file and add the wallpaper PNG you want and then compile it..
I will release another update with even more changes..I will make the clock size smaller then. :-)
