lock the launchbar
arkangeluk
does anyone know how to lock the widgets on to the launchbar at the bottom of the screen as im sick of them being deleted. im using adw ex and usually its the widget for tweetdeck that gets deleted. this time its my shortcut to the keypad thats disappeared. does anyone know which dialler or keypad setting to use for shortcut as iv tried a few already and none of them open the keypad
ric
You can lock the desktop which means that you can't move or delete any icons. It's in Menu>More>Lock Desktop on my X8 so assume its somewhere similar in the X10 (I'm running Launcher Pro on my X10 now)
I'm using the same Launcher, and used to have the same problem. You can't lock the launcher bar exclusively, but you can lock the entire desktop. Just hit your left most key (Settings), there is a button in the bottom right that appears "Lock Desktop". It will prevent you from moving / deleting any icons on your desktop or launch bar.
thatll solve the unintentional deleting, i suppose i just unlock it if i want to delete apps from the screen. any help with where the keypad settting is for a shortcut?
ric
