Help Lockbot Pro glitch?
fearofth3dark
I am using lockbot pro and I noticed my phone was being woken up by all the buttons not just power. So I went to the app, menu, config and checked prevent wake up. But now the power button wakes it up fine but all the other buttons wake it up to a dimly lit lock screen. Is there a way to get it back to only the power button working like without the app?
I just paid for and downloaded pro and I am having an issue with it too. My issue is different though. Either I'm ******ed, or it won't let me set the lock screen to what I want. So how do you set the screen to the theme you want? I'll let you know if I have the same problem once I can get it to work.
This is the same way LockbotPro has worked for me since I downloaded it.
At first I didn't like it, but then it dawned on me that it may do this on purpose to conserve battery life.
Since all buttons turn the screen on, accidental button pressing is much more likely. If the screen came on full brightness you'd likely have to put the phone on the charger several times a day.
Yeah I just wish they did nothing rather than dim it, but oh well. And as for twoj's open the app, click new theme, pick the type you want, than you can edit any options you want. Or you can go to theme gallery, click on one you want, hit download. Then when you have a theme you like go to my themes on the main page, then the ones with a gold star next to them are the ones that you are currently using. If there is more than one with a gold star the lock screen changes between them.
