locks on sceen.
  • Thread starter Thread starter stmad
  • Start date Start date
S
stmad
Guest
I install a foxfi during set up it asked for a password and now I'm stuck wit a patern to unlock my screenand dont have the option to have a slide or none .need help .thanks in advance.
Hi
Nothing you can do without uninstalling foxfi. Certain apps require a level of security including at least a pattern lock screen. Vpn services also do this. It's probably best to have a lock screen anyway but you can set it not to lock until the screen has been off for up to 30mins.
Roger
