Help lockscreen notifications help!
amg1322
Member
i've googled it, i'm scavenged around the forum and i can't figure it out and i'm going crazy. all i want to be able to do is have notications on my lockscreen similar to that of ios. and no i don't want an iphone i just miss this feature. i have tried executive assistant and messaging widgets and can't seem to get them to look similar or to work the same way. if someone knows of a certain lockscreen, or lockscreen app or widget i can use to make this happen PLEASE HELP!
Under settings there's a section for lock screen, click that then click lock screen options then turn on whichever options you want. To change the shortcuts at the bottom of the lock screen just tap the word shortcuts then take away what you don't want and add what you do. You can also pull down the notification bar from the lock screen and reply to anything from there without having to unlock your phone.
thanks i know about that.. what i'm trying to find is an app or widget that would show notifications (and preview if possible) on the lockscreen. similar to that of ios lockscreen notifications
