Help Lockscreen Picture
nigsy
Hi all,
Having a problem with my lockscreen picture. I like my lockscreen to have the same picture as my phone wallpaper but for some reason the image I have on at the moment won't change.
I have tried through Display > wallpaper and tried both the single lockscreen option & the combined wallpaper/lockscreen option but no success.
I have a pattern lock on my phone - so took that off so no security and tried to change the picture - again no joy
I'm running the Omega JB ROM (V20) if that makes a difference?
V20 is OLD.... That was probably based on a leaked version. It may well be a bug in the JB firmware at that time. Update to latest first, I recommend.
D/L Omega v31 see if that fixes it!!
I'm sure I only installed V20 last week, they love updating this one, must be nearly on nightlies!
V20 was 6th September
Time passes quickly when in Android wonderland!!
Anyway..updated to V31...didn't fix the problem, but I have found out the cause.
It seems restoring the wallpaper setting from Titanium backup and then using Apex launcher causes some kind of lock in the system. So I restored all sysinfo in Titanium except wallpaper settings.
Applied my lockscreen and normal wall paper from the default launcher; then switched to Apex..and all is good again.
Ah yes, Titanium wallpaper settings cause all sorts of issues if restored. I had an issue on Gingerbread where they prevented me doping something unrelated such as changing the ringtone. It wasn't that specifically but something like that.
