Root Lockscreen Widgets
codyedmonson
I found a way to enable lockscreen widgets on stock ROM, rooted.
REQUIREMENTS:
-Root
-Xposed
-Swype lockscreen
INSTRUCTIONS:
In the xposed installer under download search for "Galaxy S5 lockscreen widgets, download install it and reboot. Simple as that! I'll attach some screenshots for proof.
PS: You can also install a module called "Maximize Lockscreen Widgets" to make the widgets maximized by default like I have in the screenshots, also No the giant annoying white lock doesn't go away while the widgets are expanded.
