ROMs Lolipop V5.0 Development Leak
  • Start date Start date
D
Deleted User
Guest
As you know google has failed again as we all knoe kit kat prevented users to alter stovk apps and update them to the latest and install them as system apps
Now ive been using lolipop and i come accross a leak in
Lolipop has folder in system/app witch has every stock app so heres what you can now do
You now replace the apk only with a newer version of the same app and reboot your device full reboot needed and youll notice a dialog saying android is upgrading and youll notice that the app you installed/ updated apps will show
If your instslling a non stock app be sure its not in a folder in /System/app/ and reboot completely.
