Any chance we will see a 5.0 upgrade for our phones, maybe even a custom rom?
I wonder if there's anyone I can talk to and see if we can get a cyanogen mod version of 5.0 on the Awe.
Hi Kelly,Any news yet? I'm still on a rooted 4.1.2 and I'm eyeing the 5.0 update.
Hi Kelly,
If you're rooted 5.0 has been available for a while. Now there are several 5.1.1 variants available, DU, CM12.1 etc. Just look in the Awe all things root section.
Your likely getting an error 7 message, meaning you'll need to update your recovery. Which recovery version are you using? Next never go to those sites for ROMs or root information, they're typically incomplete or not even for your device. You can find everything you need here...I discovered them and tried the method mentioned in the link I posted below but the directions were not clear enough for me to follow, and I got the "installation aborted" or whatever message. I'm a newb.
http://www.ibtimes.co.uk/how-install-android-5-1-lollipop-stock-rom-android-one-smartphones-1488924
http://androidforums.com/forums/root-zte-awe.2467/
Including a helpful development community.
Honestly I no longer own the device, just have some buddies there still and try to help where I can. Although from my reading I'd gather DU is the more popular ROM.Thank you. I gave up on that one I was trying. And I use TWRP version 7.5.1.3. Also, I looked into the all things root forum and saw 2 different forums that I was curious about. Both by the same person, for 5.1.1 I think. One was labeled Dirty Unicorns in the title and the other was just called CM12.1. Which one would you recommend or are they pretty much the same?
[emoji106] no worries.Alright. Thanks for helping me out!![]()
