Help Lollipop: Smartlock Trusted Places not working
gtbarry
Android Expert
I use Smartlock for Trusted Places and Trusted Devices only. It is working fine with devices (car, bluetooth headset, watch, etc). But it has stopped working with locations.
My troubleshoots:
- went to uninstall PlayService updates and reinstall them - it was greyed out and I was unable to do this.
- I removed my home location, shut down the phone and then rebooted and added the location in again
- made sure I had the highest possible accuracy settings and have GPS and wifi turned on at all times
Phone: Nexus 5
Android: v5.1
Google Play Services: v7.0.99
Any thoughts would be appreciated.
Thanks!
Are you using any apps/widgets that are able to turn the screen off via tapping the screen instead of pressing the power button?
