topjimmy17866
Did anyone else get a firmware update notice to Lollipop today ?
My 13 year old got it yesterday or the day before. Called me at work and said he hates it.Did anyone else get a firmware update notice to Lollipop today ?
Was your phone rooted ?I got the notice and when it updated it stopped at 99% and when it tried to install it said that the file was corrupted so I let it go at that. The next morning when I went to use my phone I saw that the update had downloaded and said it was ready to install so I clicked on install without even thinking about it. After a while I noticed that the phone was now stuck in a boot loop. It wouldn't do anything..just kept rebooting. The only way I could get it to power off was go into recovery. I wiped the data through recovery and tried to boot up but nothing happened except for it being stuck in a boot loop again. After going into work I found out that someone else who has the same phone had the same problem while another person was able to update their phone without issue. I ended up taking it to a Verizon store to see what could be done. I found out today that they are going to send me a new replacement phone. I wonder if it will be updated already...I shall see..and if not do I chance trying to update it.
I received a notice last week, but it would download to 99% and just sit there. I rebooted and it gave me an error message that the firmware was corrupted. Same thing the next day, so I took the phone into Verizon. After doing I don't know what, it finally downloaded and updated everything . . . everything. It will take a little getting used to the new look, but it all seems to be working, except for the charging. I usually plug the phone in next to my bed at night and leave it on. By morning, it has been fully charged and I'm good to go. Not anymore. I plugged it in the first night and by morning, the light was off and I thought it was good. Nope! Only charged up to 13% after being so dead the night before that it shut itself off. I waited long enough to be able to turn it on so I could check it before plugging in and thought all was well. I plugged in the next morning and it only charged to about 30%. The next night it was fine, so I thought the problem had solved itself. The following night, however, it didn't charge all the way again, so I changed cables thinking that was the issue. Last night, I noticed it was charging fine until a text came in. Then it stopped charging. And no, it wasn't just notifying me with the green light, it STOPPED charging. Middle of the night, so I plugged it back in. The same thing happened early in the morning when an email came in. It stopped charging. I have no idea what causes this, but if anyone finds a solution, I'd like to know about it.
