Help Long GPS lock time
no66
Hi,
having a problem with the GPS. This morning it took about 15 minutes before finding a lock in Navigation. Just out of interest, I exited Navigation and went back in. Again no gps signal. Gave up after 10 minutes. Rebooted but still nothing after 5 minutes. (Had to go and work! )
Will try later today and post my findings, but not happy.
Yes, GPS is enabled!
Running official 2.3.5 from Kies *%##!
from which location are u trying? indoors, outdoors? are u trying just GPS or have u turned on the assisted GPS part as well?
First in the car.
I rebooted again, and went outside and got a lock after 5 minutes.
Rured og gps and maps, turned back on and locked in after about 5 sec so it seem to have fixed itsself!
Will test again on my way home this afternoon while driving
Thanks
its usually the first fix in a new location (i.e. a new country) that takes a long-ish time. after that, it gets a lock within a few seconds, for me. is this the first time ur using GPS on this phone, or is this a sudden problem ur noticing?
