tmaertin
as the title says, i am looking for a better system info widget/app. i was using temp + cpu Pro, but that app is crashing on android 4.3 (i have a Samsung Galaxy Note 3 btw).
I am currently trying Mini Info Classic, and it seems like what i am looking for. However, if I want to go pro and get full widget mods ability, it appears some people in reviews have had issues with having to pay the developer more than once after certain updates. I am all for paying someone for their work, but I also like a clear cut expectation of how its going to work ahead of time.
I have also tried widgetzoid, but it does not read my ROM/SD card contents correctly and will not report on my SD (sees internal as SD card).
Does anyone have any other/better suggestions to try? A screenshot would be appreciated if possible as well. Paid or Free - thanks to Samsung I have $50 in Google Play credit burning a hole in my Otterbox!
Thank you for all ideas!
