I just bought a Rooted Nexus S from ebay. It is running this ROM Nexus S ICS 4.0.4 stock OTA ROM (IMM76D)
Now, I know nothing about android, I'm coming off a serious of old turd phones because i'm always breaking them. I'll probably break this one too, but hopefully not for a while.
When I got the phone I put the battery in and turned it on, then charged it overnight. It will only charge to 54% and stay there. I talked to the seller he said it charged normally for him. He said he did a complete wipe and USB wipe before he shipped it.
The battery seems to drain normally (I guess, I have nothing to really compare it to) from 54% but it would be nice to have it charge to the 90% -ish range haha. I allowed the battery to drain to 40% and put it back on charge, it been on charge for almost an hour and will only charge to 41%? Do you guys have any ideas what I can do to fix this? Is this a sign it needs a new battery, or a software glitch? The seller said the battery shouldn't need replacing.
Also in the battery app under setting, Android System is using 28% is that a lot?
My last question is an important one to me haha. Is there anyway to convert the querty keyboard to a T9? I 've gotten used to texting with one hand and T9 makes it so much easier to do so.
Thanks everybody!
Thanks everybody!
