Looking for a Stylus For LG Connect 4G
4ubest
I am looking for a stylus that will work with the LG Connect 4G as I am probably several decades older than most folk here and have lost the hand steadiness to hit the correct keys when trying to type on tiny letters.
Also is there a keyboard to get that is free that will have the backspace keys that DO NOT erase previously typed text? Thank you
Do you want arrow keys? If so then take a look at SwiftKey. It has them, but they are not visible by default. This phone also has some extra gesture capabilities. You can set it so that a physical tap to the side of the phone moves the cursor.
Also, on a note of arrow keys, gingerbread keyboard has them: press and hold the spacebar and slide upwards to show them. To hide them, simply press and hold spacebar, and slide down to hide them. ( I found that out by accident ) :-)
And I can confirm that any capacitive stylus should work, as stated in the post above.
Yes I purchased from Amazon a bag of 10 or so for about $15 and taking the first one out, it seems to work great and now I can hit the letters of the keyboard that I want most of the time.
Radio shack sells touch screen pens for consecutive touch screens.
I got one for $14.99 at radio shack.
