Looking for an Android phone compatible with MetroPCS.
Must have the following:
  1. Android 4.0 and up
  2. No more than $130
  3. Used or refurbished
  4. Must work with MetroPCS
Any help would be much appreciated!
Hi Mikeandrd9213, I moved your thread to the Device Comparisons forum :)
MetroPCS uses T-Mobile so any T-Mobile phone will work - it might need to be unlocked first.
A good place to buy used smartphones is Swappa, since used phone prices vary you can check out their unlocked section for your price range:
http://swappa.com
