iulianzaharia
hello, i own a galaxy s2 plus (i9105p) and i am new to android and samsung too. the battery life is really lousy (8 hours average). i was wondering if anyone can point me to an application that can do the following:
when i shut off the screen (the button on the right)
1. switch from 3g, 3.5g, wcdma to GSM
2. shutdown mobile data (either on gsm/gprs/edge or wcdma)
3. disable sync
4. activate power saving.
and when i press the button again to pass from gsm to wcdma, open mobile data activate sync. basically the opposite.
please know that i am not accostumed to sophisticated application and i would really appreciate an answer that can point me to a simple application that does that (paid or not).
thank you
3. disable sync
thank you
