Apps Looking for developer to assist with ad SDK integration
Hi folks. I'm hoping to find someone who can assist with integration of a new ad platform into our Android game. We use a dev kit for the game which goes through NDK and the source is tied down to AdMob. We don't want to use admob and would like to expand our options.
If this sounds like venture you're interested in helping with then please contact me here and we can get in touch for more info.
Thank you!
There are many other Ad sites that provide sdks that can be integrated into your apps
Eg :
Flurry
Domob
Drawbridge
LifeStreet
Inmobi
MdotM
Jumptap
Thanks, I'm checking it out.
The main issues are that I don't know what I'm doing with java very well and the dev kit I'm using is all set up for AdMob. The calls to create/display/destroy the ads are made through a hardcoded interpreter. There are methods in the java files that can be modified, but I have very little confidence that I'd be doing it correctly. Therefore I'm actually looking for someone who would be interested in taking a look at the project to see if it is possible to replace the current methods with another SDK for ads.
I've tried it with Millenial Media and just couldn't get it to work. Mobvista seems to give more thorough instructions for dummies like me, so maybe I'll have better luck with it. In the meantime, I'm still looking for someone who would be willing to help out.
If the java code was something I had built I would be much more capable. Thanks!
Hey!
I'm Sohan from InMobi.
I'll gladly assist you with integrating the SDK into your app. What do you need ?
Hi Sohan. I'm not sure how far you folks are willing to help, but I'd need someone to actually take a look at the java files with me. Please email me at naplandgames at gmail dot com. Thanks.
