Looking for dimensions on extended batteries
jerofld
Fixing stuff is not easy
Hi guys,
I'm looking for the dimensions on the 'super' extended cells that are available for the Evo 3D. Just the cells themselves, not the covers or anything. I have this idea for a extended cell in the slimmest possible case, preferably one with a kickstand. I have some ideas on what case to use and how to modify the case, but buying 3 or 4 extended batteries to see if this is plausible seems excessively expensive. So if some of you who have extended cells could please give me length x width x height and the brand/model/capacity of your cell, I'd be greatly appreciative. And, of course, I will post my findings and any possible instructions if I get my idea to work.
Specifically, I'm looking for dimensions on:
Trexcell 3500 mAh cell
Gorilla Gadgets 3400 mAh cell
Incredicell 3500 mAh cell
But I'd also consider, but would try to avoid due to price:
Seidio 3400 mAh and 4000 mAh.
Murgen Power 3600 mAh
Or any other cells you can provide details on.
Thanks guys/gals!
From what I recall all of the batteries you listed with the exception of the Seidio Batteries are going to be a 2 cell configuration using cells that are
5.4(thickness) x 51(width) x48(length) mm
There is also a PCB attached to the cells which adds approximately 5 mm to the length of the battery
