patch321 Well-Known Member Jul 27, 2010 #1 looking forward to playing on a big screen! need controller help though
Vulcan Android Enthusiast Jul 27, 2010 #2 if your playing on a big screen save some time and cash and get Zsnes of pc or mac or even linux
Z zerokiwi Newbie Jul 28, 2010 #3 You'll also have to root and install CyanogenMod 6 as it's the only build for the EVO that supports connecting a bluetooth controller.
T talz13 Well-Known Member Jul 29, 2010 #5 HKD said: Wiimote??? Click to expand... Once you're running cyanogen mod, then yes. I look forward to installing that as soon as CM6 final comes out...
S skittlesV1 Well-Known Member Jul 30, 2010 #6 talz13 said: Once you're running cyanogen mod, then yes. I look forward to installing that as soon as CM6 final comes out... Click to expand... are you talking about CM6?
B Braaainz Android Enthusiast Jul 30, 2010 #7 zerokiwi said: You'll also have to root and install CyanogenMod 6 as it's the only build for the EVO that supports connecting a bluetooth controller. Click to expand... Sorry, but you are wrong. The gamepro drivers work on uprooted evos. It won't work with a Wii controller, but there are a couple of other options.
