Long press on the back button (bottom right) and the window will appear on the left side of the screen.
Currently there are two ways, a none root method that requires you to modify the apk files yourself, and a root method which requires you to replace 1 or 2 system files.
Or you could even install a custom ROM that already has the root method.
Hi pool_shark, wondering if there are any non-technical method? The ways u mentioned sound too complicated![]()
To my knowledge those are the only methods. Editing the apps is the easiest because it doesn't require root.
Hi pool_shark, how do I go about editing the apps? Please advise. Thanks.
