Looking for specific battery option.
nitramus
Now that I have a new phone I am using my old one as a mp3 player and want to monitor my battery.
Specifically I'm looking for a app that will let me add a widget with the option to change the time remaining ie. for audio playback or even video....
I know there are a lot of apps that show the time remaining for different states but I want the widget version.
Also maybe a good and small app with an alarm when the battery reaches a certain %.
Thanks.
Thanks.
Battery HD does exactly that. It takes time at first to run tests to calculate exact time remaining, then breaks it down very deeply as far as Voice talk time remining, video playback remaining, camera remaining, etc. I highly suggest you check it out ;)
thank you. this is exactly what I was looking for. Now if only it had power profile management it would be the absolute one and only.
