Root Looks like ive messed up...
hello forum!!!
ive got an X10mini for an early crimbo present and i had the one click rooting thing - tit backup and the busybox... but in a haste to be update to date with android ive updated to 2.2 and now i just get a FU Goo error...
have i messed it up all together or can i downgrade or what?:confused:
You can't install 2.2 on an X10 except for a very alpha version, and it's not available on the X10 Mini.
Try reinstalling everything with PC Companion.
right kool kool - my bad it must be 2.1 - but still why wont the universal androot work? - shud i try the z4root - or whatever is it?
thanks for quick reply
ok that worked and its rooted - so far as i can tell anywho - installed tit backup and ive got superuser back - only thing is the Z4 button aint changed from root to unroot... :-s anywhos im happier :D - thanks guys
