Help looping after flash
Cruzrock
Hello ... i thought i bricked my phone because it wouldn't get out of recovery. it would just show the android guy and an exclimation point. If i hit hot it toggles from revovery to the android guy. wont factory wipe or reboot or any of the options.
I flashed with heimdall ... it seemed ok for a second. it gets to wallpaper on my home then reboots. I tried the tip to hold the volumn and power but that just puts me back to the same recovery problem I was having to start with. I wont get past that still.
Please help .....
want to add ... it all started after my phone was in recovery of rom manager i selected wipe partition cache. i have done this with my phone and it seems to clean it up. Now i have tried all the steps i can find here and on xda to get it back or to factory wipe. Thanks for anything you can do
I got it running but not back to original. Some apps are broken. And I'm still afraid to try recovery again. One thing I can't seem to find that seemed to have started it all is I need a pit file for partition. Even the Verizon stock files I have found do not put it back to how it was. It's buggy now. But better than being bricked. Does anyone know if Netflix is planed for tabs. I have 1.3 but it won't work most of the time when teathered to my phone.
