No, I’m saying that one run tracking app can act differently than another.
Here’s an experiment on my phone:
Enable GPS in settings.
Assuming there are no nav/gps apps running, you will not see anything in your notification bar (you may see something if you pull down the notification bar to expose toggle/indicators, but I’m talking about the bar at the very top always in view without pulling down).
Now, start Osmand and press map to display map. You will see the gps icon now in the notification bar (blinking while trying to lock, solid after locked).
Now, press your home button to go to your launcher without exiting the Osmand application (it just goes to the background). Notice, the status bar gps indicator goes OFF.
Try the same thing with Navfree. Open it up and the gps indicator displays in status bar. Press home to push Navfree to the background and the status bar gps indicator stays ON.
Did you notice the difference? The status bar gps indicator stayed on when I pushed Navfree to the background but it went off when I pushed Osmand to the background (assuming no other apps running at the time). Navfree kept polling GPS when in the background and Osmand didn’t.
Guess what, if you have Navfree running, there is no tendency to lose lock when you push the application to the background. If you have only Osmand running, it stops polling and easily loses lock while in the background (especially if you’re moving while it’s in the background).
Also screen timeout behavior of your phone may be important. I think some apps will allow gps to be disrupted if the screen goes off... others will not.
There is a tradeoff between saving battery and agressively polling to keep lock...different apps approach that tradeoff with different priorities.
Tasker has the ability to request GPS location and there are options to request a single fix or to continuously request fix. If I use Tasker to continuously request fix, then the gps status indicator stays on no matter what’s going on. So I can use that to keep from losing lock when I'm using Osmand. But it will use more battery and get a little warmer.
Look at your status bar gps indicator and it will give you a better idea what’s going on. When it goes out, it is very easy to lose lock.
